April 24, 201015 yr OBD II Outback 2.2 liter installed into 89 GL w/ Single Range 5spd. I've got most of the wiring sorted out. BUt I ran into a potential problem. The VSS. On OBD I, the ECUs used a reed switch based VSS mounted in the speedo head. But for OBD II, the VSS is mounted in the trans where the cable would go. So, If I mount the Outback VSS into the trans and hook it up, the ECU will be happy........but I'll have no Speedometer. But if I don't hook up a VSS, the Engine will be REV limited to just over 4k. (I know because the donor car had a VSS fail and had said rev limiting occur. Replaced and ran fine till it was wrecked:rolleyes:) What have others done? Maybe I'll look into what it would take to install the Outback Speedometer head into the dash.
April 24, 201015 yr Here is a link for a product that should work for you http://www.enginewiring.com/catalog.htm and a thread that may shed some light. http://www.ultimatesubaru.org/forum/showthread.php?p=852061
April 24, 201015 yr Author VSS wire from the ECU. to the reed switch in the gauge cluster. Done. I knew it was that easy with the OBD I. I thought however that the VSS in the OBD II cars with electric speedo produced waveform, and the simple on off of a reed switch won't work? If you think it's fine, then I'm not gonna worry much then. I'll hook it up on monday. thanks
April 25, 201015 yr All the PCM is looking for is a square wave. Frequency determines speed no matter if it's obd1 or 2. I just hooked up my 86 dash vss to an 03 legacy PCM and then using a scan tool watched the PCMs readout. It read just like the dash with no issues.
April 25, 201015 yr Author All the PCM is looking for is a square wave. Frequency determines speed no matter if it's obd1 or 2. I just hooked up my 86 dash vss to an 03 legacy PCM and then using a scan tool watched the PCMs readout. It read just like the dash with no issues. This is EXACTLY what I wanted to here. After reading you're VSS thread, I figured as much, glad for the direct comment here. Thanks again King, and all the USMB. I will post a new thread when the car is done, and add a photo in the who's who sticky.
April 25, 201015 yr Author Here is a link for a product that should work for you http://www.enginewiring.com/catalog.htm Looks like I won't need this for the 89. But It may solve the issue I had of a complete lack of any type of VSS in the '81 wagon when I did that EJ swap.
