mwills Posted April 27, 2010 Share Posted April 27, 2010 so my right rear seatbelt won't release. its drawn tight. no slack. stupid thing. i checked with my favorite upholstery place and they suggested the scrap yard and they'd install it. checked my favorite local yards and came up empty. looks like i'm headed for the dealer...which is fine...but does anyone have any suggestions?? i'm thinking i'm having someone install a new assembly. any thoughts? thanks for any help. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted April 27, 2010 Share Posted April 27, 2010 year make and model. i think some seat belts have a lifetime warranty. call the dealer and ask. Quote Link to comment Share on other sites More sharing options...
mwills Posted April 27, 2010 Author Share Posted April 27, 2010 98 forester S...thanks... Quote Link to comment Share on other sites More sharing options...
mdjdc Posted April 27, 2010 Share Posted April 27, 2010 I have a 98 forester parts car that I can pull one for you. Let me kow if I can help you out. Mike Quote Link to comment Share on other sites More sharing options...
mdjdc Posted April 27, 2010 Share Posted April 27, 2010 By the way, they are easy to replace. You can do it yourself. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 27, 2010 Share Posted April 27, 2010 Might just be the lock is jammed. Try pulling the belt up towards the reel, and see if the lock releases. If you can't get it loose that way, pull the bottom seat cushion up and unbolt the belt from the floor pan. Quote Link to comment Share on other sites More sharing options...
djmark7 Posted April 28, 2010 Share Posted April 28, 2010 maybe the belt frayed and jammed, happened to me with my '98 leg free replacement, check with a dealer first Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted April 28, 2010 Share Posted April 28, 2010 remove seat bottom 2 bolts. pull up cushion remove bolt going into the latch portion of the belt, the part with the red button to release. Tension will ease, you will be able to unbuckle. put all bolts back in. Quote Link to comment Share on other sites More sharing options...
mwills Posted April 29, 2010 Author Share Posted April 29, 2010 thanks alot all...i'll do this before going any further with it. -mw Quote Link to comment Share on other sites More sharing options...
