May 12, 201015 yr I have a 2002 OBS and want to lift it a little - I know people have used legacy outback struts and/or springs...any thoughts or suggestions? Thanks, Steve
May 15, 201015 yr On an 02 impreza wagon, use forester struts/springs to lift it. You'll want the forester trailing arm brackets for the rear too, to center the wheel in the wheel well.
May 15, 201015 yr On an 02 impreza wagon, use forester struts/springs to lift it. You'll want the forester trailing arm brackets for the rear too, to center the wheel in the wheel well. I have a 99' Impreza Wagon, would the same hold true for using Forester Struts/Springs and trailing arm brackets?
May 15, 201015 yr I have a 99' Impreza Wagon, would the same hold true for using Forester Struts/Springs and trailing arm brackets? yes
October 10, 201213 yr Interested in doing both the Subtle Solutions lift with forester springs. Too much? Also do i need to get forester suspension parts from my same model year or are they interchangeable from 93-07. Got a 2002 Impreza OBS
