February 16, 200422 yr Are the EA82 & EA82T heads interchangeable? Are there any differences between the two heads, ie.. valves,...? Would I have to modify a Turbo head if I could install it on my non-trubo EA82? Thanks!
February 16, 200422 yr Author sorry guys, just did a search & got my answer. NO. MPFI & Trubo have two intake ports & SPFI (& Carb I presume) only have one port. Thanks anyway!
February 16, 200422 yr Author No. I need non-turbo head(s) but was hoping that a turbo head may work.
February 16, 200422 yr carb and spfi heads will interchange. but the passenger side head may have a different egr fitting. usually its on the top, but some carb heads have it near the exhaust port. driver side heads are no difference if the egr location is different, just keep the egr tube that goes to the head, since it connects to the intake in the same location(i suggest you look and compare first)
