Will impreza springs fit a 95 legacy?
I will be upgrading from the stock struts to the KYB GR2's I will be lowering the car at the same time (Oh My!) I was going to do H&R springs but they are a little bit pricey.
I was looking at these here
http://cgi.ebay.com/ebaymotors/Subaru-02-03-Impreza-WRX-M2-Coil-Lowering-Low-Springs-_W0QQcmdZViewItemQQhashZitem563cec40d7QQitemZ370389303511QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
ok looks like I need rear WRX tophats
can you describe?
i'm hoping to install 2002 WRX rear struts and springs in my legacy. i have the struts and springs, but no top hats. so you're saying i'll need top hats, i can't just swap the legacy top hats from the legacy onto the impreza stuff?
can you describe?
02' WRX springs have a taper at the top so I would need matching tophats for the rear I did run into a tread on NASIOC which listed when and what models can use what springs.
Only thing I can't figure out if lowering springs will fit the KYB GR-2's I have
CRACK, i was hoping it would be as simple as putting the legacy top hats on the impreza struts/springs. thanks, glad i know now before i start trying to do it.
Yeah that's what I was hoping too :(
