soobme Posted February 18, 2004 Share Posted February 18, 2004 Are the front brakes on an EA82 any bigger or better than on an EA81? Can U use EA82 front steering knuckles on an EA81? When U do the rear disk conversion on an EA81, what all do U need to do? (ie: master cyl. , lines, proporshining valve, ect.) EA81 brakes.....I don't like 'em! I miss my 4 wheel discs! Quote Link to comment Share on other sites More sharing options...
Subadoom Posted February 18, 2004 Share Posted February 18, 2004 The convertion to rear disk is not that hard. They show you what to do in the Ultimate Subaru Repair Manual. Matt could probably be a bit more helpfull because he did his. -Robert Quote Link to comment Share on other sites More sharing options...
Qman Posted February 18, 2004 Share Posted February 18, 2004 The brakes are slightly bigger on the EA82's. Unfortunately, you can not use them on an EA81 without modding in the control arm. Rear discs have been covered many, many times. Backing plates, calipers, and rotor/hubs. It is a simple bolt on that doesn't require any other changes. Quote Link to comment Share on other sites More sharing options...
soobme Posted February 18, 2004 Author Share Posted February 18, 2004 That's cool, I plan to make new lower controll arms any way:D Quote Link to comment Share on other sites More sharing options...
JWX Posted February 19, 2004 Share Posted February 19, 2004 why just stop at the EA-82 brakes go for the EJ series? there even bigger Quote Link to comment Share on other sites More sharing options...
MilesFox Posted February 19, 2004 Share Posted February 19, 2004 hub and axle. unless you swap to a 25 spline tranny, OR see if a 23 splined trubo ea82 doj will fit on a legacy axle? Quote Link to comment Share on other sites More sharing options...
