tomtomtom Posted June 25, 2010 Share Posted June 25, 2010 hello, i'm drawing up on CAD my weber carb adaptor to fit my 32/36 DGAV 5A and there seems to be a clash between the bolt hole centres? i've looked at this; http://www.ausubaru.com/wiki/index.php?title=ENGINE:WEBER#Adaptor_Plates and http://img12.imageshack.us/i/img1444n.jpg/ and it seems my hitachi must be different dimensions? i'm in uk so i dunno if that makes a difference? when drawn up they certainly won't go together like the one on this. the bolt holes on these off the hitachi are well inside the weber bolt holes??? I was thinking of just getting the manifold off and welding/ milling it to suit my weber. would you suggest I do that instead? Confused. Cheers, Tom Quote Link to comment Share on other sites More sharing options...
ShawnW Posted June 25, 2010 Share Posted June 25, 2010 Honestly if you have the means to weld/mill the intake I would certainly be tempted to do that. Especially if you can make it so you can use the tall air filter for the Weber. Different hitachi....the ea81 hitachi and the ea82 hitachi here are slightly different but I don't know over there if it would be. (assume you are in AUSTRALIA) but that could be a dumb assumption. Quote Link to comment Share on other sites More sharing options...
renob123 Posted June 25, 2010 Share Posted June 25, 2010 Honestly if you have the means to weld/mill the intake I would certainly be tempted to do that. Especially if you can make it so you can use the tall air filter for the Weber. Different hitachi....the ea81 hitachi and the ea82 hitachi here are slightly different but I don't know over there if it would be. (assume you are in AUSTRALIA) but that could be a dumb assumption. Since he says he's in the UK, yes, that could be a dumb assumption:lol: tomtomtom, Is it going into that wagon in the other picture on imageshack? The directions on ausubaru are for a 1981 ea81, so don't be surprised if it's a different size/shape. Jacob Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 25, 2010 Share Posted June 25, 2010 EA81 vs. EA82 Hitachi's have a different base pattern. You can't get the Weber adapter plates over there? Seems a waste of time when the adapters are $35 unless you can't get one for some reason. I don't know about you, but an hour on the mill is worth a lot more to me than $35. GD Quote Link to comment Share on other sites More sharing options...
tomtomtom Posted June 26, 2010 Author Share Posted June 26, 2010 There doesn't seem to be much of a Subaru scene in Uk so a weber adaptor plate is gonna be a find. I think it would be better welded anyway, maybe less restrictive as you don't have big chokes tapering down into small chokes? Quote Link to comment Share on other sites More sharing options...
