Lego Clearance question.
How large would my lift have to be to clear 29" tires on a 91 Lego with outback struts on? Also any ballpark prices. Have looked some up but I don't want to go any higher than I have to to get decent clearance. Thanks guys.
I would say 4" to fit those tires,but then I am not sure how much outback struts lift the car.IIRC they lift the car about 2" so then a 2" strut bottom lift?
Ok and this has to be added to the lower end of the strut correct? So that it can clear the tire under the perch?
I have a 98 legacy- with the SJR 3" kit, with outback struts...
FYI I also have all my suspension from a 91 legacy wagon (mine was rusty, so I replaced it from a 91 parts car, it all is the same stuff underneath)
I have 27x9.5" superswampers, and I have not trimmed anything- I think with some slight trimming you could easily fit 29" tires, as long as they are not 9.5 inches wide- I would go narrower if possible- it would require less trimming/pounding...
otherwise just go with some 28's if you can, they would fit a little better
