August 6, 201015 yr any one tell me pros and cons how much psi can i run with out any problems im new to the turbo game any help is good help
August 6, 201015 yr A lot of folks have run about 5 psi or less though the 2.2's without issue. They often get about 200 HP from them under boost. There is a lot more to adding a turbo to a non-turbo car than you think though. GD
August 6, 201015 yr Without some sort of engine management and a better fuel system, you will blow it up. The engine itself will hold up to boost fine.
