Philbiker Posted August 19, 2010 Share Posted August 19, 2010 Hello. Please forgive me if this has been covered; I did some searches and didn't find anything particularly useful. I want to read and reset the codes when my check engine light comes on. The reason is that there is a fuel sensor in my gas tank that occasionally sets off the check engine light. It's done this three times since 2004 and every time I've had to go to a shop to get the diagnosis. I'm not going to replace the whole gas tank for this intermittent problem which doesn't affect anything really. I'm not sure what I need in terms of cables, laptop, and/or software. Is there a simple intro to this somewhere? I couldn't find it here. I know lots of people here can read the check engine codes, and there's lots of info on this coming up in my searches, but not a simple "how to" with the cable, etc, at least that I could find using the searches I tried. Quote Link to comment Share on other sites More sharing options...
bstone Posted August 19, 2010 Share Posted August 19, 2010 Rent a code reader from AutoZone or AdvancedAutoParts. Click the "erase code" button. Or disconnect the - terminal battery for 10 minutes. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted August 19, 2010 Share Posted August 19, 2010 Year and model would help us give more info. Quote Link to comment Share on other sites More sharing options...
Cougar Posted August 19, 2010 Share Posted August 19, 2010 I assume you have a car that was built after 1995. The cars after that use OBD2 standards. To read the codes and reset the ECU you will need a reader or scanner device that uses the proper protocal to read the data. You can check out places like EQuus or Actron for models to choose from. The Equus 3010 is a good model I think. Make sure any unit you decide on will work with the ISO-9171 protocal. Any of the Equus models will work. http://www.iequus.com/Product/OBDII/ Quote Link to comment Share on other sites More sharing options...
J A Blazer Posted August 19, 2010 Share Posted August 19, 2010 Get a codereader at Costco. $30. Quote Link to comment Share on other sites More sharing options...
