diamondjumper Posted August 21, 2010 Share Posted August 21, 2010 So i have my 5 inch lift on the car, its pretty much done, but i had a question, we were trying to figure out if anything needs to be bone to the shift linkages? the tranny, motor were dropped 4 inches from stock. Thanks Jeff Link to comment Share on other sites More sharing options...
SoobieDoo Posted August 22, 2010 Share Posted August 22, 2010 It'll probably need lifting an inch or so then. Mine's a 4/3 lift, so also 1" suspension over stock, and I just eliminated the rubber "cushion" from the plate directly under the shifter. Post#70: http://www.ultimatesubaru.org/forum/showthread.php?t=95517&highlight=trail+wagon&page=7 Link to comment Share on other sites More sharing options...
diamondjumper Posted August 22, 2010 Author Share Posted August 22, 2010 Hey nice write up! I think that will work, im only an inch taller so, maybe just make alittle taller block, but taking the rubber spacer out ill see if that works tomorrow! Thanks! -Jeff Link to comment Share on other sites More sharing options...
SoobieDoo Posted August 22, 2010 Share Posted August 22, 2010 Thanks, at the time I had no welder...but I'd recommend doing so. Link to comment Share on other sites More sharing options...
