August 21, 201015 yr So i have my 5 inch lift on the car, its pretty much done, but i had a question, we were trying to figure out if anything needs to be bone to the shift linkages? the tranny, motor were dropped 4 inches from stock. Thanks Jeff
August 22, 201015 yr It'll probably need lifting an inch or so then. Mine's a 4/3 lift, so also 1" suspension over stock, and I just eliminated the rubber "cushion" from the plate directly under the shifter. Post#70: http://www.ultimatesubaru.org/forum/showthread.php?t=95517&highlight=trail+wagon&page=7
August 22, 201015 yr Author Hey nice write up! I think that will work, im only an inch taller so, maybe just make alittle taller block, but taking the rubber spacer out ill see if that works tomorrow! Thanks! -Jeff
