Ej Wiring help..
Can anyone help......? (its a 91 EJ22)
So i got almost all my Ej Wiring done it seems that i am not getting signal to my ignition...... but my starter is working.... I do not have a O2 sensor hooked up and was wondering if that would "lock" or stop it from getting ignition.....?
Also is there an alternator lock out i heard someone talking about this at one time but am not sure if that is true....?
Thanks
Reid
ignition, start and fuel relays all are separate, if you don't have all 3 that could be your issue.
O..... i will def check that out tomorrow any other ideas i cant hear my fuel pump run....
did you even check what I suggested?
Make sure you're getting voltage to the relays, make sure they click and make sure you're getting voltage to the other side of the main ignition relay.
Def check those relays with a DMM. You should be able to hear that fuel pump. Try using the stock FP relay as a test...hell, my EJ one still isn't hooked up. :eek:
