Inane Cathode Posted September 19, 2010 Share Posted September 19, 2010 Hopefully a somewhat easy question this time. I'd like to get into the data stream on my ecu. I want to see whats going on with the idle that way. I've got the tactrix 1.3u cable (from evoscan) they say it's compatible with my96 models, but i cant for the life of me figure out how to communicate with my computer. I've got the obd connector on the end of the cable, as well as another 9 pin block connector of some kind. I need some help from someone experienced in this area, i'm not sure what to do with it. Do i need to have the subaru select monitor plug to use this cable? I can wire one up if need be, but i thought just the obdII connector was good enough. Quote Link to comment Share on other sites More sharing options...
OB99W Posted September 19, 2010 Share Posted September 19, 2010 You've mentioned both the cable and your computer, but not the software. What program are you running? Cable info, includes links to software: http://allobd.com/proddetail.asp?prod=TAC-OpenPort1.3U&cat=45 EvoScan: http://www.evoscan.com Quote Link to comment Share on other sites More sharing options...
