ellets Posted October 14, 2010 Share Posted October 14, 2010 I am trying to reassemble my engine.I didn't take it apart. (long story) I can't locate timing mark oncrank gear.Iknow that it should be opposite the key and supposed to be a mark on crank position sensor but I cant find it. Also is the little line on cam gear the timing mark? And on this engine (ej22t) how are the cams set. I see the mark on plastic behind cam above gear. I am comfortable with ea82 but am lost with this thing. Help please Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted October 14, 2010 Share Posted October 14, 2010 the timing marks should be on the flex plate, also both cams up on the EJ's the plastic backing will have marks for the timing. There is a tooth count between the gears, don't recall off the top of my head, but someone here will Quote Link to comment Share on other sites More sharing options...
