October 16, 201015 yr I have a 93 legacy turbo that is a 2.2l trying to get the trouble light code cant find any green wires or any black one that arn't connected
October 16, 201015 yr I have a 93 legacy turbo that is a 2.2l trying to get the trouble light code cant find any green wires or any black one that arn't connected http://www.surrealmirage.com/subaru you are looking for green connectors or black connectors, not wires. they should be under the dash to the right of the steering column. if they have never been used they may be taped up in a wire bundle. josh's site will help, look around there for info. look for 'notes and tips' then 'engine related'. Edited October 16, 201015 yr by johnceggleston
October 16, 201015 yr look up by the steering column, and over towards where the cigarette lighter wirings are. I have seen some over by the fuse box area above the brake pedal as well and one of them over nearer the lighter socket. sometimes theres only one plastic connector and the other side is just a metal spade tip. wire colors are dog crap brown, and then black.
October 16, 201015 yr Author ive been told theres a certain obd 1 and others what is a 93 legacy turbo and I found a scan connector but was wondering if I could disconnect the memory connector and connect another connector to troulbe shoot or what's the deal thank's
October 17, 201015 yr Author :-\ I was wandering if the 93 legacy turbo is a obd 1 or obd 2 cuz i cant find the connector wires for self diagnostic and was wandering if someone could send me a link or point me in the right direction for diagnosing it like how to connect and disconnect the connectors and if not where's the best place to find a obd 2 scan tool that's it for now thank's for all the help:-\
October 17, 201015 yr http://www.main.experiencetherave.com/subaru/images/ecuhide.jpg http://www.surrealmirage.com/subaru/images/ECU_connectors_1.jpg http://www.surrealmirage.com/subaru/images/ECU_connectors_2.jpg
