JDM motor ID?
KootenayJK
Is it turbo or non-turbo?
Non-turbo EJ20 SOHC had the plastic manifold for a while in the mid 90s, turbo with plastic manifolds came in 2004, first on the Legacy TwinScroll Turbo.
Those engines are very sensitive to tune and break easily.
Well, he has already removed the manifold from the block, and I did not get to see the block. I'll have to ask more ?'s next time I'm out there.
Gotcha. It'd be pretty tough to identify the motor by just the manifold. ha ha
BTW, hello, neighbor! If you're in the Kootaneys, we're practically neighbors. I'm just south of you in eastern WA.
Back to the engine...:grin:
If it stil has the timing belt covers, there is a chance that there still is a sticker with barcode and engine code on the center cover. I bet it is either a EJ20X or EJ20Y, depending if it is MT or AT.
Those engines have dual AVCS (variable valve timing on intake and exhaust) and a compression ratio of 9.5 (high for a turbo, hence senstive to tune and easy to break).
