95-99 Outback Climate Control units - all the same?
My vent settings are 'stuck' as I posted about recently.
In doing some eBay and internet searching, I'm encountering 2 different listings for the control units. 95-97 and 98-99. Some listings though are indicating that the units were the same across all these years, or at least compatible.
Does anyone know? Eg will a 98-99 unit work ok in my 1997 Legacy Outback?
Just from the pictures, I can see that the blue/red temperature band was changed from a continuous solid bar to a dashed colored bar. I guess that could be enough to have generated a new part number. Otherwise, it looks identical. My concern is whether the electrical connection / circuit board is the same or not. I'd hate to buy a unit and then find out that it doesn't hook up.
Thanks.
From what I remember, they are all the same (Size/shape) few little changes light you said. But should pop right in.
Be carful not to loose the E-clip that holds the lever cable to the box (Hard to fine one that works other then the proper one)
Cheers,
-Tom
unhook the cable from down below, not the unit itself
