November 2, 201015 yr I have all the 4x4 parts to put into my 1993 Loyale, Will all of these parts just bolt on? Or will there be some welding and such needed? Any other help with this installation would be much appreciated. Thanks in advance. -493
November 2, 201015 yr all the holes for the 4wd stuff should be there. Some models don't have all the holes drilled so you would have to drill those if it doesn't have them... you will need a 4wd gas tank if you don't already have one unless you are lifting it at the same time. Edited November 2, 201015 yr by Uberoo
November 2, 201015 yr rear diff support bar will need holes drilled in the body, , I used long bolts up into the floor with large washers, also driveline center bearing will need a mount , I welded up a bracket with 2 bolts
