brumby420 Posted November 3, 2010 Share Posted November 3, 2010 im have a 1985 jeep cherokee with a 2.5 liter 4 banger and it was just running last week but then died out and wouldnt start. i assumed it was just out of gas as what usually happens when you romp in a jeep all day long LOL. yesterday though i try adding gas to start it up and it would just turn over and not show any signs of wanting to go. i checked and it was getting fuel and i know it haqs good compression and air flow so that leaves spark/timing as the two culprits. i took off the spark plug and coil and turned it over. I saw it wasnt getting any spark what so ever. The spark plug is good and the coil didnt seem corroded so i guess that would likely mean the distributor is bad. What im wondering though is could it be possible that a wire got knocked loose inside it cause correct me if im wrong but i didnt think that distributors just broke like that unless they got got into very deep water which it hadnt at that time. Another question i had is how likely is it that it could have jumped time or something like that. It didnt really knock or do anything weird so i dont think it did but i have no idea why it would just go out like that. Lastly im hoping i can figure out this issue on my own but if not if anybody knows a good honest mechanic who charges a fair price in the North Idaho, east Washington area if you can get me their contact info that would be great. Quote Link to comment Share on other sites More sharing options...
WRX2FFU Posted November 3, 2010 Share Posted November 3, 2010 Distibutors don't fail that often. I would check the cap and rotor first. The coil can still fail even though it looks good. Also check the wires feeding the coil and maybe look for a blown fuse... Quote Link to comment Share on other sites More sharing options...
brumby420 Posted November 3, 2010 Author Share Posted November 3, 2010 Ok thanks for the help. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 4, 2010 Share Posted November 4, 2010 (edited) Check for 12v at the coil? Check coil resistance? Check for 12v pulse from negative side of coil when cranking? C'mon man - pull out the DMM and find the problem. Guessing won't work. Distributors can and do fail "just like that". I've seen it - of course the only time I've seen it is on Mitsubishi's - but then Chrysler is in bed with those idiots so you never know. Personally I steer way clear of Jeeps and all other Chrysler products. I prefer my cars and trucks to actually run a good percentage of the time - more so than seems to be allowed by Chrysler's build quality. GD Edited November 4, 2010 by GeneralDisorder Quote Link to comment Share on other sites More sharing options...
brumby420 Posted November 5, 2010 Author Share Posted November 5, 2010 i think i would have noticed but do you think its possible I broke a cam or broke something in the timing Quote Link to comment Share on other sites More sharing options...
Abineefelligh Posted April 11, 2011 Share Posted April 11, 2011 My name is Dan. I am new to this forum. I am having problems with my motor. I had to change the starter on it this year. Once it was changed it took forever to get it to start. I got it started and took it to the lake. Once in the water it would not run but about maybe 5 mph. I had to throttle it up carefully or it would die. I read on this forum of things to check. I have checked my compression. All four cylinders are running at 60. I have good spark on all plugs. The motor will not miss or cut out when I cover one of the carbs. I am just wondering what is up I cannot afford to put it in the shop. A mechanic said I needed to rebuild the carbs. It does not sputter, bog or anything when hooked up to the muffs. Just in the water. Any suggestions? Quote Link to comment Share on other sites More sharing options...
Ionlyhave3suubs Posted April 11, 2011 Share Posted April 11, 2011 Chrysler and Jeep I don't believe were in bed together yet in '85. They were still using 2.5 and 2.8 GM engines back then. Start out by checking for power and ground at the coil. Go from there. Quote Link to comment Share on other sites More sharing options...
