April 3, 201114 yr I'm going to be putting new CV joint boots on a front axle. Is there a procedure that I can do to be sure the CV joints are good before I put new boots on it? THX.......Peter
April 4, 201114 yr Do a full lock turn both left and right. If you hear no clicking, your joints are probably good. Mark
April 4, 201114 yr if it exhibits no noises/symptoms now then just reboot it and you're golden. i've rebooted a couple of old noisy axles before too and cleaned out with new grease they were fine, still running two of them like that. i drove them 4,000 miles to colorado and back, beat the snot out of them offroad, they made horrible racket the entire way home, i had to nurse them home by stuffing grease in at every gas stop....rebooted them and they've been perfect since even on my lifted XT6. not saying i recommend it, but they are rather robust to begin with unless you are rebooting some aftermarket junk. if it's aftermarket then they're a gamble even when brand new, if they're Subaru axles (even if really old) you'll probably be fine.
April 4, 201114 yr I'm going to be putting new CV joint boots on a front axle. Is there a procedure that I can do to be sure the CV joints are good before I put new boots on it? THX.......Peter Look for play in the joints(axle stub turns but axle doesn`t). Sometimes they can feel tight but still be noisy,but,if they are loose,you can be sure they are worn.
