April 8, 201115 yr after replacing crank pully, radiator, , now seems like power steering pump, when the belt slipped off could the power steering pump got damaged ? chrip chrip .? or after market belt, ?
April 8, 201115 yr probably not damaged. cheap belts will stretch. i gave up on mine and and replaced it. but even a good quality belt may have to be adjusted after awhile of driving. check and see how much deflection / tension you have in the belt. you want less than 1/2" i think.
April 8, 201115 yr ok, but 98 forester does have 187,000 on it, thanks so it's not a new belt? maybe it should be if the crank pulley fell off.
