Hi Im Austin proud owner of a 1984 Subaru BRAT GL
where would i get an lsd
If you get lucky, you can score one at the local junkyard. Check out early Turbo GL wagons and RXs. Or find one here in the for sale forum. I have one which I may be selling in the future. Make sure you match the gear ratio. You have a 3.900 rear now and the LSD needs to match. Most of the turbo LSDs come with 3.700 ratio, but you can pull the LSD "chunk" out of the 3.700 unit and install it in a 3.900 "open" differential. Lots of write-ups on that. Good luck with your new Brat.
  • 2 weeks later...
