parts catalog
could someone please either direct me to where i can find subaru part numbers or give me the part number for the trim that surrounds the gauge cluster/air vents in a 89 XT?
Have you tried calling your local Subaru dealership?
I was looking for some parts for a 1982 Subaru GL. I started by looking online as just found a bunch of after market stuff, nothing officially that could convince me to buy anything.
I needed specific body body parts and some other stuff. I was able to find the following. All from the dealership...
Left, & Right Marker Lights ( Single Corner Lamps)
PCV Valve
Water Pump OEM
Oil Pump OEM
Clutch Kit OEM
It takes some time for the dealership but if you are patient and have the VIN number then you may be able to find some of your parts. Some occasions the parts I was looking for they would be completely out of, and some had limited quantities.
I was patient gave them a list and they called me back when they got around to looking them up.
Carter Subaru in Seattle is very good, and they handle a large volume of inventory with a lot of old part catalogs. If you ask for the part number you can order them from your nearest dealership or they can ship to you.
It's worked for me.
Good Luck!
Rollerball
i don't believe the dash bezels are available any more. a bunch of folks on the subaruxt.com forum have parts manuals if you want to check there. i had my scanned electronically but the person that did it has since been unavailable so we haven't hosted it.....yet.
*i just tried to contact him again.....
Edited by grossgary
