14inch tires with 4 lugs
NorthernWestern!
i need help find right kinds wheel of 14 inch plus 4 lugs.
I've been looking but there wrong fit of lugs on my Subaru GL wagon.
please let on message for whats kind wheel of 14inch or 15inch.
thanks!
Subarus use the 4x140mm bolt pattern. There WERE some 14" Subaru wheels in existance, check your local boneyards and you might get lucky! Pugs (Peugot) wheels are another option, but they have funny lugnuts that are sometimes hard to get and I'm unsure which series to look for.
You can also redrill 6-lug stuff (6x5.5" GM truck or 6x139.7mm Toyota/Nissan/Datsun/Isuzu/etc) to Subaru bolt pattern, since the spacing is almost exact. You just need to drill two holes and countersink them 60 degrees.
Can do redrill on white soke trailer for make of my Hub Wheel 4 Lugs on subaru GL?
Nope. That is 5 lug.
You must find a 6 lug like mentioned above to drill the wheels out, and you have to do it just right or a tire place wont touch them.
If youre looking to offroad, find a set of peugeot steelies, they appear on here from time to time, and most of the people on this board sell them with the lugnuts included.
If you just want something bigger without going offroad, the turbine style alloys are 14s I believe, again, they appear on here from time to time.
Take a good look at the FAQ at the top of this forum.
Or, take a good look at the Subarus of the 80s page done by McBrat.
This topic is now closed to further replies.
