BrightonFuture Posted May 19, 2011 Share Posted May 19, 2011 Hey guys, I tried to search the fourm with no results. I'm sure its well documented but I couldnt find it. anyway just looking for a a short answer. I wanted to know if the Automatic transmission from an EJ25 (1997) will work on an EJ22 (1997) (Auto). Thanks in advance guys. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted May 19, 2011 Share Posted May 19, 2011 not unless you swap in the matching ej25 rear diff as well. they have different final drive ratios. but that is the only difference. Quote Link to comment Share on other sites More sharing options...
BrightonFuture Posted May 19, 2011 Author Share Posted May 19, 2011 Awesome! Thank you. Quote Link to comment Share on other sites More sharing options...
987687 Posted May 19, 2011 Share Posted May 19, 2011 You have to use the ej25 torque converter and flex plate with the ej25 transmission as well. Quote Link to comment Share on other sites More sharing options...
