May 27, 201114 yr I have an ej22 from o1 impreza mated to an xt6 5mt, ea82 flywheel and pp. I am using the car's original starter from fwd 5spd. I think i remember there is a slight clearance issue. I need to know how much spacing is needed, the best manner to do so, or if i should use a different starter. It shounds like the bendix gear is dragging along when the engine is running. I have only run the engine long enough to start, and to test alternator oputput.
May 27, 201114 yr I've never had an issue. And a quick look at parts listings doesn't show any difference from FWD to AWD/4WD. So as long as it's for a 5MT, it should be just fine.
May 28, 201114 yr What thickness is the adapter plate? If the plate is too thin, then the flywheel will be too close to the starter. It should be 12-13mm thick. Otherwise, if the starter fits the trans, it should work fine.
May 29, 201114 yr Isnt there a difference with the throw on an auto v.s manual starter? Say if you have an auto trans and a starter for a manual you could get the symptom you describe or if you have a auto starter on a manual car it could not fully engage the flywheel and eat teeth some times.
May 29, 201114 yr The snout on an auto starter is a different diameter, so it wont fit in a manual transmission.
June 2, 201114 yr Author I swapped the starter out wit the one that was original to the engine and adapter plate behind a 4spd ea81 trans. Still had the starter dragging with the flywheel. I put some washers between the trarter and the trans and that cured it. I used ea82 head bolt washers. I would have used thinner ones if i could find 2 that matched out of my 5 gallon buckets of subaru hardware. I cannot explain why it was rubbing, but the variable was 4spd vs 5spd trans with this particualr adaptrer and flywheel(ea82)
