June 14, 201114 yr I need to replace a splined hub on my wagon (the part that the lug studs are mounted to) and was sent one with a lip on the inside where the splines are. The ones that came off the car have splines nearly to the edge of the cylindar. I have a feeling they won't work, but thought a check here would do me some good (I attached a pic for reference.) Anyone?
June 14, 201114 yr Chances are If the hub part with splines does not look the same it will not fit. Local yard will have them pretty inexpensive.
June 14, 201114 yr But they will fit, at least an ea81 hub works on an ea82. same dimensions, heavier casting. It might be different the other way around Edited June 14, 201114 yr by MilesFox
