July 10, 201114 yr Hello all, I spent a grueling 2 hours in the sun today...just to properly fasten a few clamps on my Subaru's air intake system. One of the clamps was very loose... Well, now the engine runs much more smoothly and the backfire problem I previously alluded to has pretty much been eliminated completely. So the moral here is ----> a properly aspirated Subaru is key to its smooth operation. (But you experts already knew that....right?) --Damien
July 11, 201114 yr You might also run a smoke test to find any other leaks, but you probably licked it. I just ran a smoke test and it found three vacuum leaks! 2 just needed a clamp and one needed a new gasket. Bang and done.
July 13, 201114 yr Author I found one more hose that was not properly fastened...so that should about do it. Now it hardly backfires at all...(esp. now that I got the clutch...uh...adjusted). --Damien
