Transmission will not shift
't95 OBW when it's been sitting for a few hours, get in put it in D and take off it will not shift out of 1st. Drive about a mile and it will finally shift into 2nd. Another mile or so and so on it will eventually shift through all. When it dosen't shift and I let off the gas it coasts like in neutral until it slows then it will pull again.
I had a similar experience when a speedo drive broke on another car. sppedo works here though. I am thinking VSS at the trans.
how can I check for that?
304,000 miles
MT or AT?
Is the AT Oil Temp light flashing when you turn the car on?
Getting a Check Engine Light?
Looks like an auto since he mentioned "putting it into D".
When was the last fluid change? Sounds like the solenoids are just a little bit gummed up, but start working after everything gets all warm. If you haven't did a trans fluid change lately, start with that and see where it gets you. Look up "4eat fluid change" on here and you should find the drain and fill 3 times method.
