bonvos winter warrior
Well a much as it might stink, please post pics of your swap job to the Weber. I am still learning that swap and if you get to experience it I personally would appreciate some pics, instructions.
I really want a wagon now too. :banghead:
  • Replies 235
  • Views 40.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • theres only one thing i enjoy more than a garage motor build...... thats one i get to watch not have to do lol
  • well i leaned something new about my engine the water pump is completly contained the cast pipe up top is what connects it to the cooling passages instead of having everything inside the block half ca
  • you would have to come to lapine and i have no way to pay ya lol but if your game pm me
im not swapping a weber on it im still screwing with the stock carb and its pissing me off like there is no tomorrow
so the thing ran great idled awesome but it had a stumble due to the accelerator pump not doing its job found out that the one that came with the rebuild kit was different so we swapped back to the old on since it was only 6 months old now its back to square one!! im so ready to push this damn thing off a cliff right now i mean its a great car when it ************ing runs but this pile of crap carb is killing me
the topper is all i need to put a weber on this thing is a freaking adapter i already have the carb
Edited by bonvo
Soooo do the swap when ya get an adaptor. Then you can enjoy her again.
problem is i need it running now and an adapter is more then my budget allows right now unless someone has a used one
well its plugged the carb up again while fine tuning it yesterday so today i decided enough was enough so i pulled the tank just to be sure
i think i found my problem.....
so now to clean the tank and the rest of the fuel system
i think i want to re index the rear torsen bars while im back there how do i get these things apart
Edited by bonvo
today went out to look at the tank all the gas had evaporated and dumped this out of it
went down the car wash and used there pressure washer nozzel to get everything out going back in tomorrow along with the cleaned carb
i also found some spring spacers in the garage and put them in the front struts didnt lift it much i got maybe an inch inch and a half out of it
got the subi tank clean and put back in lines clean gas filtered 4 times and carb is back in the chem dip tomorrow i should have a running car again....FINALLY
ok so after cleaning the entire fuel system cleaned and bolted the carb back on
and with fingers and toes crossed and a quick prayer to the car gods
i turned the key and got this
Lol. Priceless! Hopefully it will stay running good for awile now.
it should now that there is nothing to plug the carb up
  • 3 weeks later...
alright guys im finding myself needing to take a trip back down to california to attend a funeral this is around a 800 mile round trip ive noticed that around here the speed limit is 55 mph that is about 3500 rpm the speed limit in cali is 65 which ive tested and found that to be about 4200 the question is would this thing be able to handle it for roughly 600 miles? seems like its alot of revs for a long time
  • 2 weeks later...
%^&&%$ how come after all of that it snows and i loose the accelerator pump im so freaking done with this carb as soon as my weber adapter gets here im putting a 30/30 round threw this hitachi
well a few days ago i started to take it apart pressed down on the accel pump and it worked so i made some changes to the rod so i get more squirt out of it and put a much heavier return spring on it now the throttle is heavier but it runs drives and idles again this will get me threw till i get my weber adapter
  • 1 month later...
this shot should live here me and the warrior
thats almost exactly what im looking for lol but i already have a car that needs an engine rebuild i really dont need another
  • 1 month later...
replaced the battery cables today and found out that it still had the original battery cables  it cranks over alot better now and the entire electrical system is much happier
  • 3 weeks later...
well i was driving home from bend on sunday and as i pulled into the driveway at 9 oclock at night it died and wouldnt crank over due to a dead battery well today i finally got around to looking at it and found my problem
after looking it over i looks like it was the original belt or close to it new belt and problem solved
Edited by bonvo
well compression test figures disappoint me at about 100 psi so rebuild is in order i have found some parts on rock auto to make this happen for under 200 bucks but i cant find crank main bearings i can find con rod bearings but no main bearings they also dont offer different sizes so does that mean overbore pistons arent available? if thats the case that makes things a little easier
How tall are you? I'm 6'2" and wondering how well I'll fit into one of these wagons.
im 6'1" 330lbs and getting in and out of this thing isnt exactly graceful or enjoyable but thats more my weight cause im fighting between the b pillar and the steering wheel
head room isnt bad neither is leg room though the seat has to be all the way back and i have to move my right leg around to shift
Edited by bonvo
Haha, cool. I'm pretty flexible so I shouldn't have any problems. I really enjoyed reading your posts about getting your 78 up and running. Have you had any more carb issues since cleaning the fuel system so thoroughly?
no more carb issues now its gonna get a rebuild due to my lacking compression
