September 21, 201114 yr Anyone know what numbers I should be looking for? I don't see it listed under the engine or electrical section of the service manual and I'm trying to figure out these ignition issues.
September 22, 201114 yr Author I don't feel so bad now someone else looking can't find the numbers as well.. Going to test the fuel pressure this afternoon Some more data info This is WOT up to 4th gear for timing MAF Driving around 65 mph (no 5th gear so rpm is high) Took this last night
September 22, 201114 yr Author One person says my coolant temp should be like 180-190 while driving.. I don't think so right? It seems rather normal
September 22, 201114 yr One person says my coolant temp should be like 180-190 while driving.. I don't think so right? It seems rather normal My coolant is 182 while driving. Goes down to mid 170's if I'm going down a long hill, climbs up to high 180's going up a really long steep hill. But 182 is the average.
September 23, 201114 yr Author It's the torque app for Android using a bluetooth OBDII reader.. Anyways having said that Hmm I don't think a normal car can pull the timing all the way down to 0 degrees.. I'm going to do the plugs next but I saw something like 1.1K ohms for both?
September 24, 201114 yr Holly smokes... you are doing 4.4 million RPMs there! I have a PDF that may -or may not- help you somewhat. Shoot me a PM with your email and I'll send it to you.
