EA-82TT Engine Management Swap
I'm looking for a garage for the winter to put this car together. Must have heat. The engines and a lot of the parts are in the car or at another garage I use.
Doug
I'm thinking a custom set of Wisco pistons for one motor. I have a strong desire to have custom head studs made, then offer them to other builders.
I need to have a couple EA 81 head studs in my hand. Hit me up if you can sell them to me.
Doug
Edited by Quidam
  • Replies 177
  • Views 44k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • 17.1 second 82 mph quarter mile basically stock GL-10 for reference.     I want to trailer my car to National Trails Raceway in Columbus, Ohio next season. NHRA track.   Doug   http://www.dr
  • Starting to regret posting those heads.     I got excited, thought they were neat.
  • Hey Doug.  Good to hear from you.  Say, I've been runnin' late model Legacy front struts and hubs on my 88 GL10 wagon for several years now.  I started with XT6 stuff, but didn't want to be stuck with
On my last build I used EA82 head studs on the EA81. Studs torque better than bolts.  Steel thread on Steel bolt vs Aluminum threads in the block.
"On my last build I used EA82 head studs on the EA81." That should read, EA 82 head bolts, correct?
I need studs because if you overtorque head bolts you WILL distort the bore and that's to be avoided at the power level I'm going for.
One motor I'll have to preheat the engine with block heaters to even start it. Total Seal piston rings and Wiseco pistons full custom.
Doug
Steel inserts and larger studs than the EA 81 is definitely on the table. Except for the fact that builders may opt for, and I'll sell more of the stock thread.
Fat studs is what I really want and steel inserts would be icing on the cake.
Doug
Edited by Quidam
