SmashedGlass Posted October 24, 2011 Share Posted October 24, 2011 How hard is it (1988 GL wagon)? I have one that is shattered from the PO, only thing holding it together is the window tint lol. Quote Link to comment Share on other sites More sharing options...
SmashedGlass Posted October 25, 2011 Author Share Posted October 25, 2011 Someone on here has to have changed one before... Quote Link to comment Share on other sites More sharing options...
88 EA82T Posted October 25, 2011 Share Posted October 25, 2011 You need to determine if the old window is clipped in or glued in. I am assuming that you are talking about the rear quarter window and not the rear door window.... On my '88 GL10 the rear quarter window was glued in. I tried to buy a window from the local junkyard but they broke it trying to get it out because of the glue and their delicate technique. So I ended up having the body shop change it out for me, they got me a used window and installed it for less then $100 if I remember correctly. Hope this helps. Quote Link to comment Share on other sites More sharing options...
SmashedGlass Posted October 26, 2011 Author Share Posted October 26, 2011 That does help a little, thanks. I guess I'll go "practice" a removal in the pull'n'pay to figure out all the trim removal. Quote Link to comment Share on other sites More sharing options...
cal_look_zero Posted October 26, 2011 Share Posted October 26, 2011 Can't help but point out your username... Fixed glass is something I never have, nor will mess with. I can change out door glass all day long, but won't trust myself to get a good seal/not break the glass. However, the easiest method I can recommend for removal, is to go to HF and buy a couple of these: http://www.harborfreight.com/4-1-2-half-inch-diameter-suction-cup-40993.html Fasten one to the roof or body of the car, another to the glass in question. Tie a rope or cord between the 2 handles so if the glass all of a sudden frees up, it's less likely to hit the ground. Cut the seals with a razor knife and liberally spray the rubber with WD40 or similar to help free the glass up. Don't pry or force it. Quote Link to comment Share on other sites More sharing options...
Quidam Posted October 27, 2011 Share Posted October 27, 2011 How hard is it (1988 GL wagon)? I have one that is shattered from the PO, only thing holding it together is the window tint lol. Ha. My 87 GL 10 had it's right rear sideglass broken in a wind storm. Tint all that's holding it in too. And duct tape, but haven't driven the car like that. I need to change it, but first I have to get one out of a parts car first. I've got three good ones, hope I don't need that many:). Oh, I've got the suction cups but have to round up the right blade. I think I'll look for something flexible, like my paring knife. Doug Quote Link to comment Share on other sites More sharing options...
SmashedGlass Posted October 27, 2011 Author Share Posted October 27, 2011 That suction cup is a good idea, hadn't thought of that, thanks. I think I'll also go downtown this morning and nab some used guitar wire from the guitar shop... wish the piano shop hadn't closed, that would probably have been a better source. BUT........ now I have to wait a few days to even think about this repair as we got about 4 inches of snow yesterday but it should be in the 60's again by Saturday. Gotta love Colorado! Quote Link to comment Share on other sites More sharing options...
1982gl4 Posted October 27, 2011 Share Posted October 27, 2011 (edited) I just broke the rear window in my lego, and had a replacement glass on another hatch ( the hatch was in worse shape or I would have swapped the whole thing). I used four guitar strings and broke everyone of them, gave up with those I cut a throttle cable out of another car I had, and that worked much, much better, just a thought if you run out of them! Edited October 27, 2011 by 1982gl4 Quote Link to comment Share on other sites More sharing options...
Quidam Posted October 27, 2011 Share Posted October 27, 2011 Here's mine and I need to get the trim off without tearing anything up. Wasn't so easy last time I did it. I'll probably use black weatherstrip adhesive in place of the trim seals that seem to nearly always disentegrate. Doug Quote Link to comment Share on other sites More sharing options...
mdjdc Posted October 28, 2011 Share Posted October 28, 2011 The best wire for removing a window intact is 100lb test fishing wire. It is strong enough to do the job and thin enough to work with. Get it between the glass and the outside and then use two wooden dowels to pull it along with. You will not really have to do any sawing with it. I have removed alot of glass that way. It is fairly cheap too. Just don't know haw available it is in your area. If you need some, let me know and I can go to the local shop, get you some and ail it to you. If you need the window, or bung up the trim, let me know I have a parts car sitting at my friends shop and I can pull whatever you need Good luck Quote Link to comment Share on other sites More sharing options...
SmashedGlass Posted October 29, 2011 Author Share Posted October 29, 2011 Thanks MJ, I'll let you know. Going hunting for next week for that 100lb line and to the yard for windows, this weekend I have a narrow weather opportunity to do my wheel bearings/tie rods/cv axle so that's what I'm concentrating on. Quote Link to comment Share on other sites More sharing options...
mdjdc Posted October 29, 2011 Share Posted October 29, 2011 If you can't find the window, let me know and I will pull one from my car and send it to you. It is already tinted too if that helps. My daughter got hit in the front end and the car is totalled. Lots of good stuff still on it though. Quote Link to comment Share on other sites More sharing options...
