November 9, 201114 yr I just bought the car to use for work,I deliver newspapers.It has 141.255 miles (2.2 liter) and It's got a oil leak that it appears that it's coming from the timing covers,I suspect it's going to need new belts and a complete oil seal kit.Can you fellow members guide me towards the best place to order my parts and price.Do they sell a complete kit that I can order?????Thank you.Bill:)
November 9, 201114 yr From that location it's most likely from the cam seals or crank seal. On that era, some of the screws on the back of the oil pump could loosen up, possibly letting oil leak out the crank seal, and sometimes even pushing it out completely. Get the cam and crank seals from a Subaru dealer, they are not overly expensive and are good quality. Oil pump should get resealed too, mainly to see if the screws are loosening up. So get a discharge o-ring from Subaru too. If you want to do a timing belt and idlers, there are kits on eBay that people seem to like and are not very expensive. Could replace the valve cover gaskets too if desired.
November 9, 201114 yr Congrats on the new car! A lot of us feel pretty good about "theimportexperts" kit--you can get the belt, idler pulleys and a water pump, all for a reasonable price. And all you need for the oil pump is one o-ring (I'd get it from Subaru dealer) and a tube of Permatex Ultra-Grey. While you have the pump off make sure you Loctite and tighten up the backing plate screws. Try a search on here--there are some good writeups from the past. Good luck Bill! Edit: Agree with porcupine--definitely do the cam and crank seals! Edited November 9, 201114 yr by Olnick To add info!
November 9, 201114 yr Author I will be checking out all the information you guys have posted it,Thank you for your responses.Bill
November 10, 201114 yr Let us know how it comes out Bill! Now.....it shouldn't go without mentioning.....that if you are unhappy with your engine.....your chassis a popular one for installing one of the Japanese market twin turbo Subaru engines. More mail delivered, less time!
November 11, 201114 yr Timing kit from ebay (including water pump), OEM stuff from online dealer (subaruonlineparts worked for me). There are several threads that include parts numbers and all relevant information
