Lachlan Posted November 24, 2011 Share Posted November 24, 2011 So if you've ever taken off your wiper motor, you'll see that the motor has a steel ball which sits in a white plastic socket in the wiper driving bar. And if you've ever taken off your wiper motor, you probably broke the little white plastic socket. Does anyone know the name or part number for the socket, or know where to source a new one? Thanks Quote Link to comment Share on other sites More sharing options...
obk25xt Posted November 24, 2011 Share Posted November 24, 2011 I'm not sure about the historic gen stuff. BUT! I had the same problem with a 2000 outback, I called the dealer in hopes of getting the white plastic socket piece. It was futile, I ended up paying $200 for an entire assembly. Your best bet is to attempt to source one used I'm assuming. In my case rainX did wonders while I searched for a used one, only to end up buying the new one from the dealer..... RainX is your friend Quote Link to comment Share on other sites More sharing options...
moosens Posted November 24, 2011 Share Posted November 24, 2011 Looks like its not a seperate part from the manual. Buried away I've got some arms ,etc. , so probably another member here has them too but accessible. Quote Link to comment Share on other sites More sharing options...
Lachlan Posted November 26, 2011 Author Share Posted November 26, 2011 Poo. That's not what i had hoped to hear. Thanks for the enlightenment, though. I guess I'll hit the junk yard and see what I can find. Quote Link to comment Share on other sites More sharing options...
xman Posted November 26, 2011 Share Posted November 26, 2011 You can try getting a replacement in the 'Help' brand replacement generic parts at the local auto parts store. the package has an assortment of sizes and shapes. I found one that for in my 93 impreza. Good luck. Quote Link to comment Share on other sites More sharing options...
DR DLEX Posted December 4, 2011 Share Posted December 4, 2011 ....or use washer/spacer...cone it using a punch(to ride the ball)...cut a slice from center to edge...bend to slip over ball...bend back...then grease the ball the wipers may have a little slop,but it works Quote Link to comment Share on other sites More sharing options...
