January 24, 201214 yr This is the wifes 87 gl-10 green dash not amber. Has been clicking in the dash for a few years, just wanted to know what I should check in there. Auto trans with cruise also. Hush
January 25, 201214 yr I also have a 87 Gl10 with the same dash is the dash doing anything weird? Speedo not working odometer not working something of that nature? Or is it just clicking?
January 25, 201214 yr Author Clicking and the speedo jumps around a little (at 45 it jumps from 41 to 48 or so, been just going with the number that shows up most often.). Everything else works fine. Hush
January 25, 201214 yr its the speedo cable. it might have worked its way partially out or its probably just very worn and needs replacing. or the speedo assy. needs some lube... lol if you pull the gauge cluster out the problem should be easy to spot
