March 23, 200422 yr Ok, well I let austin attack it, we removed all the emissions compononts, and he ignored the egr valve, cause he told me usallaly they're stuck closed. So we go to fire it up, and it won't idle, runs at 2,500rpms or higher just fine, but any lower and it died out. after swaping carbrators on it 3 times, we realised that the egr valve was actually stuck open, not closed, providing a major vacume leak! austin covered it and like magic the engine ran normally. So now it's de-emissioned, running smooth, and ready to be tested to see if it fails or passes:clap: I'm replacing the distrubuter with one that doesn't have massive shaft play, hoping that helps, and the only other thing it needs is a return spring for the carbrator. So I thought I'd share the news of today's adventures. It's amazing what obvious things pass the eye. it just needs some slight tuning wich will be done tomarrow, and I should be set. The passenger side cv outer joint however is making all sorts of noises on me when I turn, so it's time to replace that.
March 23, 200422 yr So if i read that right... you said you failed and then decided to rip the emissions stuff out to have it re-tested? Good luck -Brian
March 23, 200422 yr Washington state is much easier on emissions than California. If the car passes the sniffer test, the hood is never raised. However, best of luck anyway. Glad you guys found the problem with the idle.
March 24, 200422 yr Author yeah, but it's still running to rich and failing, Austin has access to a sniffer at his work. We're gonna try diffrent carbrators today until we find one that works... Turnes out the other Night Ed that the egr valve, unlike what austin thought, was stuck open instead of closed, so theres this half inch vacume leak lol! We never noticed it until finally he thought of covering it just for the hell of it, and like magic, the car idled normally. So now to find a good carbrator out of the 20 in his shed lol, wish us luck today.
March 25, 200422 yr Author I guess intake manofold gaskets would help..... now it runs smoother than most subarus I hear driving on the road today.
