rear bearing
rusty/bent brake parts (dust shield) are rubbing. having the rotors turned or wiring brushing them will alleviate some noises like this. really need to remove the rotor and get the inside tract as well where the e-brake drum brake bits are, and that seems to be where noises like this come from the most for me.
ok, rear disc, thanks
right - rear discs have DRUM brakes and shoes for the emergency brake inside the rotor of the "disc brakes". if you don't know what i mean, remove the rotor and you'll see. when there are rusty lips and ledges in the rotor they rub and cause noises. wiring brushing or having them turned will fix it.
or it's the wheel bearing. replacing the hub isn't a terrible idea though if you've never had at those rear lateral link bolts be prepared for a nightmare if you don't take some precautions. around these parts they rust and corrode in the bores/sleeves and shear off easily. they are no fun to remove. soak it a long time in the best rust penetrant you can find.
if you have a temp gun you can verify bad wheel bearings by hitting the hub after a long drive - that side will be consistently hotter than the other.
