April 30, 201213 yr Hopefully someone knows more about this than i. The brake light in the dash of my 91 loyale has been on for about 3 days. I checked the fluid level. Its good. None of the lines are leaking. Pedal travel seems good. I do hear a little bit of a grinding noise in the back passenger side. Im thinkin maybe the booster is goin out. Any ideas?
April 30, 201213 yr It must be a Stickin' Float Sensor for the Brake Fluid on the Master Cylinder's Reservoir... I Kindly Suggest you to Check it. Kind Regards.
April 30, 201213 yr wiggle the parking brake handle and see what that does as the parking brake illuminates the same lamp.
May 1, 201213 yr Author Just went off today after work. I checked fluid level. I checked the float inside. I checked the rubber thing under the cap. Everything was normal. I guess the float may have been sticking and for some reason let loose today.
May 1, 201213 yr Author Just curious if anyone else has noticed the ridges in the brake drums on an ea82 car.
