91 subaru Posted April 30, 2012 Share Posted April 30, 2012 Hopefully someone knows more about this than i. The brake light in the dash of my 91 loyale has been on for about 3 days. I checked the fluid level. Its good. None of the lines are leaking. Pedal travel seems good. I do hear a little bit of a grinding noise in the back passenger side. Im thinkin maybe the booster is goin out. Any ideas? Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted April 30, 2012 Share Posted April 30, 2012 It must be a Stickin' Float Sensor for the Brake Fluid on the Master Cylinder's Reservoir... I Kindly Suggest you to Check it. Kind Regards. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted April 30, 2012 Share Posted April 30, 2012 wiggle the parking brake handle and see what that does as the parking brake illuminates the same lamp. Quote Link to comment Share on other sites More sharing options...
91 subaru Posted May 1, 2012 Author Share Posted May 1, 2012 Just went off today after work. I checked fluid level. I checked the float inside. I checked the rubber thing under the cap. Everything was normal. I guess the float may have been sticking and for some reason let loose today. Quote Link to comment Share on other sites More sharing options...
91 subaru Posted May 1, 2012 Author Share Posted May 1, 2012 Just curious if anyone else has noticed the ridges in the brake drums on an ea82 car. Quote Link to comment Share on other sites More sharing options...
somick Posted May 1, 2012 Share Posted May 1, 2012 It might be your alternator going bad. Sam Quote Link to comment Share on other sites More sharing options...
