A/C Issues, 05 Legacy Outback
My A/C temperature fluctuates, from nice and cold to tepid. I've had the refrigerant level checked, and it seems ok. Can't seem to locate any obvious problems. Anyone have any suggestions, or experienced the same problem? Any help and/or advice would be greatly appreciated! Thanks!
How was the refrigerant level checked? Did someone put a set of gauges on and read suction and discharge pressures while the AC was running? (There is no way to know what the charge is in a system without evacuating and re-charging with the correct amount of refrigerant.)
Off hand, I'd guess you are low on freon. Maybe get a can of R134a and a charging hose with a gauge. Available at your local auto parts store. Instructions should come with the kit.
If that doesn't cure it, you should find a pro.
