anbody have an idea why the auto door lock just quit?
do you have a factory auto lock/unlock switch? does it work as it should?
depending on who installed the alarm and the model, there might be a fuse between the unlock relay (either IN or external of the python alarm) and the unlock (action) wire. check the wire harness of the alarm for breaks, also check fuses. IF there is a relay, you might check it too if you can.
-Justin
