June 1, 201213 yr head gasket torque. EA82 Sohc 1 step-22ft lb 2 step 43 ft lb final 3 step 47ft lb and 90 deg add? no re-torque. am i right? need new bolts?
June 1, 201213 yr This sounds right. No re-torque, and you can used the original bolts, they are not stretch bolts like the EJ motors.
June 1, 201213 yr No on the 90 degrees.......at least by the factory specs. Neither EA or EJ engines use torque to yeild bolts.
