June 14, 201213 yr will drive shafts from a 90's NA ej22 liberty (legecy) fit in a 98 2nd gen OUTBACK? im only interested in fronts
June 19, 201213 yr Author well it does fit, but i just swapped complete hub/control arm/drive shaft from the 98 outback in to my 90 liberty (legecy)
June 19, 201213 yr This is valuable information! I knew from my own recent experience that the knuckle/hub is identical between the 92 and the 96. So unless there was a wholesale change to the diff dimensions, I don't see why the geometry would be any different for the axle. Even the tone ring was identical. Thanks for sharing your findings! Makes for more options at the junkyard!
June 22, 201213 yr Author well heres some little pics, its only the rear mount that is a little differant
