June 28, 201213 yr I replaced my rear caliper and it was leaking brake fluid where the caliper meets the brake line. Is there suppose to be a copper washer between the caliper housing and the brake line>? I have a washer at the bolt head, but not at the caliper.
June 29, 201213 yr I have to go back and check mine now as I just replaced both of them. There should be two, one under the head, the other under the hyd hose fitting. http://opposedforces.com/parts/forester/us_s10/type_20/brake_system/brake_piping/illustration_2/
