86 gl water pump
hi everyone, my 86 gl water pump gave out. I was looking online to get another but there's too many . If somebody could help out it would be appreciated. I have an 86 gl with an ea82 engine, factory installed(?) air and front wheel drive, automatic trans, 4 door. thanks for any help.
get on ebay or amazon and get a paraut (parout?). anyway: made in japan=good made in china=bad.
Not trying to undercut you Shawn, but I have one off of my Loyale that is used but good. If you still need one. I can pm you some more info on it later tonight if you are interested.
Dealer installed air or no air = 110mm pump
Factory installed air = 105mm pump.
You can tell by inspecting the clutch fan pulley.
If the fan bolts onto the pulley, and the pulley bolts onto the pump(4 bolts and 4 studs total)...it's factory A/C......Short pump....105mm
If the fan slips onto the same studs that the pulley is mounted too, i.e. pulley is sandwiched under the fan(4 studs only).....it's dealer air.....110mm pump.
Most likely you need the 110mm.
Hey I have it, but I can't find it so I'll post when I do if you still want it.
Ok, I found it. It is off of my 91 loyale with a 5 spd manual trans ea82. This should be the same water pump that on your GL. It was working when I pulled it from the car, I was just doing some TLC. It has a little surface rust on the impeller, but I think that is because the car sat for a while before I bought it. I could clean it up and ship it out to you if you want to make an offer?
