August 24, 201213 yr Anyone have any pictures of the stock front door speaker hardware/brackets/etc in the later '80s GL? It looks like the PO of my wagon ditched everything when he half-assed his install, all that's left in my door is metal. No brackets, no moisture shield, nothing. Haven't looked at one in the junk yard yet as it's raining on and off today. I know you can just mount speakers to the plastic panel, but I'm trying to keep the speakers inside the door panel mounted properly for somewhat better sound quality (I'm not sure, but putting them on the outside might make them sound crappy).
August 24, 201213 yr I have both L&R door shields & the speakers with the mounting brackets for an 85 gl. Send a PM & we'll get them to you for USPS flat rate if you like. The speakers in them are Boston 4 ohm, 20W nom, 4.25". Here's the pass door: Edited August 24, 201213 yr by czny
August 25, 201213 yr Author Thanks for the offer, but I went to the pick'n'pull today and lucked out--the '89 3 door there had rings, that were factory but different from the ones you show. They were black plastic, and actually fit 6 1/2" speakers with no modification! Also grabbed the near-pristine moisture shields from the same car.
August 25, 201213 yr Good for you! It's OK - I'll list all my parts soon. Need to clean house for moving.
August 25, 201213 yr Thanks for the offer, but I went to the pick'n'pull today and lucked out--the '89 3 door there had rings, that were factory but different from the ones you show. They were black plastic, and actually fit 6 1/2" speakers with no modification! Also grabbed the near-pristine moisture shields from the same car. The 3 door has different doors than the wagon... the plastic shield will not likely fit your wagon doors. The wagon doors are shorter by several inches...
August 26, 201213 yr Author That's why they invented the box cutter They're the only ones in the yard that are in good shape, all the others were full of tears and holes. I'll make 'em work.
November 27, 201510 yr Wish I can find 3 doors in junk yards so easily Edited November 27, 201510 yr by Rocketdog
November 27, 201510 yr Are the rear speakers generally the same size as the front? Particularly in the 3 doors? eh eh?
