August 28, 201213 yr So I'm a complete amature but I had swapped carburetor's on other vehicles before and thought this would be a bit easier. I've pulled off the old carburetor, put the Weber on, beat down the power steering resorvoir so it can fit, got the throttle cable linkage where I think it can work, but I am lost with all the vaccuum lines. I know only one or two are necessary now but I have no idea which one or two. I've heard them referred to by name but this does not help me locate them. Also Im not sure what to do with the electric choke as there are three wires going to the harness and the Weber is a single lead. Do I combine them? Only need one of them? Or go from a different source? Any help is greatly appreciated. Also with me a pictures are worth a thousand words. Thanks. Chuck
August 28, 201213 yr Also, you could search for "The " weber thread. All the information you seek is in there. REad it.Learn it.Love it. cheers PS, offroad, almost top rung... http://www.ultimatesubaru.org/forum/showthread.php?t=29778
August 28, 201213 yr Welcome! ... ... You can find a Complete Writeup full of Pictures about the Weber carb Swap onto the EA82 engine, in the Followin' Link: ~► Here. I Believe your subaru is EA82 by reading your description. (For more useful info, writeups & Files, click on my Avatar.) Kind Regards.
August 28, 201213 yr Author Ya, sorry it is an ea82 in an 86 gl. Thanks. Ill look into those resources.
