September 19, 201213 yr MY 95 legacy l auto with leaky power steering pump. Anyone knows if any other MY will fit? I tried to search with no result. Thanks
September 19, 201213 yr Are you sure it's the pump itself? Often it's the o-ring seal between the fluid reservoir and the pump.
September 20, 201213 yr Almost any EJ pump will fit. Newer ones have remote resevior but will still work if you get the resevior and it's mount. Early legacy (90,91) use a smaller mounting bracket to the engine....so if you use one of those, you need to get the mounting bracket with it.
September 20, 201213 yr subaru sells a rebiuld kitt for them its like 80 $ comes with all seals and oring exept the tank oring have done many fixes leaks
